I did a few small tasks today. I started by adding a pull string to the wing wiring conduit so when I install the wings I can pull the wiring harness into the wing. I also cut out a section of the wing wiring conduit next to the auto pilot roll servo so I can attach the roll servo wiring. Next I installed the cotter pins in the main gear wheel nuts. Then I carried out the XM antenna installation. Lastly I did some cowling aft edge trimming and cowl fastener adjusting.
